Which Way Should Coil Face. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-09-2009, 09:58 PM   #1
Which way should coil face.
I have a CHPF amana coil that is an "A" type coil. The install paperwork says it is bi directional. My question which way should the apex (point of the A) face. Toward the furance or the plenum? I'm sure is just a mater of choice but you guys have done this a few times before.
Also what is the best way to attach the drian pan. Coil is attached directly to furance, drain pan is a little bigger then coil. I just want to hang it below the coil.
I don't have to get a custom one made that goes under the furance and coil do I? No water should be in the furance. If I have to get one made I'm looking at 4-5 days and close to 200 bucks. I would like to use the one I have.
Posted from my iPhone.
firedogut is offline   Reply With Quote
carrier fan coil FE4A uplfow position slope coil silica HVAC 0 07-22-2009 12:53 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 12:43 PM
Replacing a 2 ton A coil with a N coil with TX valve englewood1 HVAC 7 09-11-2008 12:09 PM
help, Poor performing AC, coolant leak? damaged coil? images maverick06 HVAC 5 07-31-2007 05:30 PM
