WATTS 3/4" 30LB. PRESSURE RELIEF VALVE - HVAC - DIY Chatroom Home Improvement Forum
Old 11-16-2011, 04:23 PM   #1
WHAT IS THE PROPER REPLACEMENT INSTALLATION i SHOULD FOLLOW TO REPLACE THIS VALVE?
lakeportartifac is offline   Reply With Quote
Old 11-16-2011, 04:31 PM   #2
newtech's Avatar
Rewards Points: 164
Need a little more info..
Do you have a replacement valve??
Do you need to order a new one??
I assume that this is on a boiler, if so pic's would help...
newtech is offline   Reply With Quote
Old 11-16-2011, 07:26 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Before we go down the road of instructions of how to replace the relief valve, answer a few questions please. Is it leaking? What is the system pressure reading?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Slantfin Galaxy Boiler Pressure Mystery chiefswabjockey HVAC 18 11-15-2011 06:37 PM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 06:00 PM
water heater relief valve dripping (with gauge readings) ziguan Plumbing 10 01-28-2011 11:12 AM
Leaking Pressure Relief Valve of Boiler rob07030 Plumbing 2 11-02-2010 08:11 AM
Water Heater Pressure Relief Valve Leaking. merton Plumbing 2 03-29-2010 08:37 PM
