Waterlogged Blower Motor Won't Run - HVAC - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 07:35 PM   #1
Waterlogged blower motor won't run
My humidifier drain clogged and apparently showered the inside of my furnace with water over two days whenever the unit was on. Eventually the blower stopped working. When it would rotate, it only went for a few seconds with the sound of it pushing through water. I dried everything out over the last 24 hours, but the fan will not start spinning on it's own and only spins at a very low speed when I turn the blades turn it on using the door panel switch. I switched out capacitors but no change.
Any thoughts on what's going on? The unit is a York gas furnace that's about 10 years old.
Thanks!
camryman95 is offline   Reply With Quote
Old 03-13-2012, 07:55 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
failed motor?
Most likely!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
plummen (03-13-2012)
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 09:06 AM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 05:48 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
