Water Under Furnace [pics Inside] - HVAC - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 11:36 PM   #1
Water under furnace [pics inside]
I noticed a small amount of water around the front/side of the furnace, so I opened the bottom panel and found rusty water pooled in the bottom. I opened the panel right above that and found the gas burners. I tried to open the panel right above that (right behind the exhaust flue) but I wasn't able to pull it out. I was able to get all the screws off, but the panel wouldn't slide to the side or forward. The lip of the flue, from the furnace, was blocking the panel from coming forward. In any case, is this the panel I should be trying to open in an attempt to check for a drain problem?
Should I be investigating the pvc drain pipe instead?
pringle12345 is offline   Reply With Quote
Old 07-07-2011, 07:02 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
I would cut the drain above the trap and blow through it, likely the trap is plugged. reinstall pipe using a union so the pipe can be taken apart at a latter date to blow though again.
OR the other problem you may have is that the coil is freezing due to low charge....You will need a PRO to find and repair this problem.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Tags
furnace water air handler
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Help with my Gas furnace..Pressure switch and water?? JASPhoto HVAC 4 12-13-2010 02:43 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Water on bottom of furnace timkay2 General DIY Discussions 5 10-17-2007 09:27 AM
