-   -   Water Staining Around High Velocity AC Port (http://www.diychatroom.com/f17/water-staining-around-high-velocity-ac-port-165136/)
Nhfixit 11-29-2012 11:06 PM
Hi.
I have a confusing problem that I cannot figure out. Sorry about the long post. Any help would be appreciated.
I have high velocity A/C. Unit works fine in the summer, no issues with cooling. I live in NH.
1-2 years ago I noticed some water staining on the ceiling next to an A/C port second floor below an unfinished attic. A/C port is in a bathroom that gets regular shower use, though we do use a fan/vent when we shower. Another port, just outside the bathroom door has some water damage next to it too. Recently I have seen some minimal water damage next to another port on the other side of the house. The roof does not leak.
I have a whole house fan in the attic, and I have three whirly bird vents on the roof. Initially, I thought the water damage in the bathroom AC port was due to water getting into the attic via the whirly bird vent and dropping on the outer surface of the A/C vent insulation (which is right below the whirly bird), and rolling down to the port and staining the ceiling. So I wrapped the surface of the insulated tubing in the attic with a towel to stop water from doing this.
However, recently there has been more staining at the bathroom port, but we have had no rain at all to prove my theory. Plus, the whirly bird vents are not above the other two A/C ports which have water stains.
So now I am thinking that this might be some kind of condensation thing. The attic is very cold now. I have never before blocked the air intake grill in the second floor hall ceiling. The AC blower is in the attic. I would think that if it was a condensation thing, wouldn't the condensation be INSIDE the AC tubing and not apparently on the outside where it is reaching the ceiling? I did notice some mildew inside the tubing.
Thanks in advance, photos below.
http://s5.postimage.org/tatrj1u3n/photo_5.jpg
http://s5.postimage.org/7d1w304gz/photo_4.jpg
beenthere 11-30-2012 04:36 AM
Supply line is probably loose on outlet and letting cold air blow out in that direction. Pull outlet down and check. Refasten and seal if the line is loose.
Nhfixit 12-01-2012 11:12 PM
Thanks for the reply. Removed the port and pulled down the duct. Duct was rotted, water pooling in the port. Seal of duct on port was no longer intact. Probably due to not plugging the duct in the winter combined with high humidity from the shower.
old_squid 12-02-2012 09:17 AM
That's why the manufacturer supplies plastic plugs to go into the diffusers in the winter time for AC only units mounted in the attic. It's to keep humidity from the home out of the cold (attic temperature) AC unit and all the tubing/ductwork. You should also block off the return air grill with something that will not pass moisture.
Nhfixit 12-02-2012 10:46 AM
Thanks. We had the plugs but are usually lax about when we put them in. Never blocked the return grill before this year. Problem is houses don't come with an instruction manual and no one even told us about the plugs. Randomly saw them in the basement and guessed what they were for.
