Water Seeping Out From York Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 01:31 PM   #1
NJK
Water seeping out from York Furnace
Hi Everyone,
I just noticed that water were collected on the furnace. It seems to be coming from inside one of the vertical panels. Here is the picture I took about 5 minutes after wiping out the collected water. You can see a new drop of water just formed.
Thanks for any suggestions !
NJK is offline   Reply With Quote
Old 06-05-2012, 01:52 PM   #2
Rewards Points: 380
Is it coming up around the screw, or is it dripping down form above?
HVACDave is offline   Reply With Quote
Old 06-05-2012, 02:10 PM   #3
NJK
Thanks for the reply, HVACDave.
It's coming from the edge between the vertical panel and the horizontal panel where the pipe is sticking out. The left-hand side of the vertical panel (not shown in the picture) is where the pvc AC drain pipe attached.
In other words, it's coming up around the screw, not dropping from above.
Old 06-05-2012, 05:29 PM   #4
An old Tradesmen
Rewards Points: 6,448
Is water coming out of the A/C drain? Could be a cracked drain pan.
Old 06-05-2012, 05:33 PM   #5
Rewards Points: 13,226
Or a plugged up condinsate drain. Find where it exits the house and see if it's dripping. There should be a pce of white PVC pipe coming out someplace.
Old 06-05-2012, 08:37 PM   #6
NJK
The AC drain comes out of this unit and goes to the sump pit which is sealed so it is hard to tell whether the drain pipe is clotted or not.
Old 06-05-2012, 08:56 PM   #7
Before deciding that the condensate drain is clogged, check to see if your coil is freezing up. Do you still have good airflow from your supply registers? A freezing coil will block the airflow. Is there any ice on the refrigerant lines that connect the indoor unit to the outdoor condenser? The easiest place to see this happening is right where the pipes connect to the outdoor unit.
Here are a few problems that can cause the coil to freeze:
- Low airflow. Is your air filter clean? Are your supply registers or return grilles blocked or covered up? Is your indoor blower operating?
- Low refrigerant charge. This will require a service call to fix. For a temporary fix, turn the a/c OFF and the fan to ON for a few hours. When the airflow returns to normal, turn the a/c back on. How quickly it freezes again will tell you how low your system is.
TopTechnician is offline   Reply With Quote
Old 06-05-2012, 08:58 PM   #8
If freezing is not your problem, then I would take a wet-vac and suck out that condensate drain. If you can't get to the end (in the sump pit) then you may need to cut the pipe. You can either put it back together with a pvc coupling and glue, or you could use a short (3") piece of 1" rubber hose and two hose clamps. This will allow you to open it up again if it needs cleaning again later.
The Following User Says Thank You to TopTechnician For This Useful Post:
NJK (06-06-2012)
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
gas water heater vent into furnace vent??? Master Brian HVAC 2 05-08-2011 01:16 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Water leaked into furnace mapleleaf HVAC 3 06-08-2008 11:54 AM
York Furnace Leaking.. Please help sidoe HVAC 4 10-08-2007 05:55 PM
