Water In Pan - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 09:30 PM   #16
amy212's Avatar
Yeah already growing algae.... ill look into that.... is it suppose 2 face upward like that anyway... seems like that could cause it to get clogged
amy212 is offline   Reply With Quote
Old 08-12-2012, 09:37 PM   #17
I'm Your Huckleberry
Rewards Points: 2,270
Is that your main drain coming from the unit or is that the secondary from the pan under the unit?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-12-2012, 10:00 PM   #18
Electrical Contractor
kbsparky's Avatar
There are supposed to be 2 drains:
1) From the unit's cooling coil,
2) From the overflow pan
Sometimes, both drains are combined into one pipe, making it easier to clog up.
The overflow pan, if it gets full has a float switch that shuts off the unit to prevent water damage to your ceiling.
It appears that you solved your immediate problem by sucking out the blockage from the drain line with your shop vac.
You may want to check the main unit's drain to ensure that it is cleared, and not still overflowing into the overflow pan.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
amy212 (08-14-2012)
Old 03-30-2013, 06:38 PM   #19
How to Locate Condensate Trap
Originally Posted by turnermech View Post
Mian drain is clogged most likely. this happens most at the condensate trap. you will need to blow out the drain line from the unit side. Or suck out drain from its termination.
Where is the condensate trap located? Also, there is ice buildup on the pipe that runs from the exterior of the house to the outside unit. What does that mean?
Laura76108 is offline   Reply With Quote
Old 03-30-2013, 07:27 PM   #20
Roofmaster
Rewards Points: 2,210
I had black mold growing in the plastic condensate pan used for the A coil in a previous home. Clogged the 3/4 inch condensate line completely, and affected air quality in the home. Plasticizer leaching from pan caused severe mold. I cleaned the pan and coil with bleach, water, soap and shop vac.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
