Water In Pan - HVAC - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 05:40 PM   #1
Rewards Points: 264
water in pan
Typical A coil 3 ton unit. Water is getting in the over flow pan. The interior pan is plastic so not rusted through. Where do the plastic pans typically leak?
Coil appears clean.
7echo is offline   Reply With Quote
Old 08-12-2012, 06:17 PM   #2
Mian drain is clogged most likely. this happens most at the condensate trap. you will need to blow out the drain line from the unit side. Or suck out drain from its termination.
turnermech is offline   Reply With Quote
Old 08-12-2012, 06:18 PM   #3
Clean out the drain coming from the pan. Probably has an obstruction in it.
hvac benny is offline   Reply With Quote
Old 08-12-2012, 06:32 PM   #4
amy212's Avatar
This happened 2 me b4 i used the shop vac 2 suction out pipe/drain from outside
amy212 is offline   Reply With Quote
Old 08-12-2012, 09:12 PM   #5
install a vent after the trap on drain line
Marbledust is offline   Reply With Quote
Old 08-12-2012, 09:29 PM   #6
Rewards Points: 12,858
That drain you have is completly wrong Amy.
Should have just been a straight line outside.
The trap was suppost to be just outside the pan.
Old 08-12-2012, 09:57 PM   #7
I'm Your Huckleberry
Rewards Points: 2,270
Amy: also, might want to dig a French Drain (absorbant rocks in a hole) for that drain line if that's your main drain. If that's your secondary drain than you as well need to have your pipes cleaned.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-12-2012, 10:07 PM   #8
amy212's Avatar
Is cleaning the pipes something that i could do myself or would i need 2 call a professional
Old 08-12-2012, 10:13 PM   #9
amy212's Avatar
My ac would not come on so i researched and i suctioned the pipe in the pic i got about 3gal of water out of it i also removed all water from drip pan it came bk on and is working fine now but i dont want 2 have future problems
Old 08-12-2012, 10:14 PM   #10
I use compressed nitrogen to blow out drain lines from the unit outwards. If you have an air compressor it may work.
It's a very simple job in most cases and I'm sure you could do it yourself but I'm going to have to say that you're going to need to call someone out, assuming you don't have a tank of compressed nitrogen or an air compressor.
Thanks.
Old 08-12-2012, 10:16 PM   #11
Did you notice an electrical float switch in your drain pan? That's a good thing to have, shuts the outside unit off in the event that condensate water backs up. Prevents water damage.
It's simply a float that sits in the water and at a certain point of being lifted cuts the electrical signal off. Once you drained the water, it lowered and allowed electricity through the wire again.
Thanks.
Old 08-12-2012, 10:17 PM   #12
amy212's Avatar
Ok well thanks 4 answering all my question
Old 08-12-2012, 10:17 PM   #13
Anytime. Anytime at all!
Thanks.
Old 08-12-2012, 10:18 PM   #14
amy212's Avatar
Yes i have the float so it didnt overflow it just shut off
Old 08-12-2012, 10:21 PM   #15
Also Amy, might want to extend that drain line from where it currently terminates right next to the condenser a few feet further away from it and your home. Eventually that condenser will sink due to that water draining right next it.
And it'll leave rust stains on your home and grow algae.
Thanks.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
