Water Not Getting To Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2015, 02:02 PM   #1
Rewards Points: 184
Water not getting to humidifier
Water not getting to humidifier, April Aire 550 with digital control, the control is a panel near the furnace, and part of my regular thermostat.
I replaced the solenoid valve, but its still not working.
When I set the humidistat to test and check the current with a multimeter its not getting any volts.
When I test the 4 pairs of wires going to the humidistat only one (the 2nd pair from the left) has voltage while its on test, and thats about 1.8 volts.
What could be the problem here?
abefroman is offline   Reply With Quote
Old 01-18-2015, 06:54 AM   #2
An old Tradesmen
Rewards Points: 6,086
Transformer for humidifier may be burned out. Should be getting 24 volts.
Old 01-18-2015, 06:58 AM   #3
Rewards Points: 184
Do transformers typically burn out with out an additional problem?
Could it be the humidistat board?
Old 01-18-2015, 07:28 AM   #4
An old Tradesmen
They do wear out on their own. Was the furnace running when you were checking for voltage. It may be wired up that it only has voltage when the furnace is running for heat.
The board need voltage sent to it to work. So since it doesn't have voltage, its probably not the board.
Old 01-18-2015, 08:16 AM   #5
Rewards Points: 582
need to see picture....don't know if its wired direct from tranformer to humidistat to solenoid valve....or if it wired from control board to power transformer when blower come on...either way when furnace is running and himidistat is calling for water you shoud have 24 volts at solenoid valve.. if not you have to trace out the circuit...
Old 01-18-2015, 11:35 AM   #6
Rewards Points: 446
As beenthere said, most humidifiers are wired so that they only get power to them when the furnace is in heating and it's main blower is running.
old_squid is offline   Reply With Quote
Old 01-18-2015, 12:14 PM   #7
Rewards Points: 184
Thanks! That was it, when the blower was running I have 24 volts +/- AC.
I'm now getting like a slow drip of water, is that how its suppose to be?
Old 01-18-2015, 01:02 PM   #8
An old Tradesmen
Should be a lot more.
Old 01-18-2015, 01:54 PM   #9
Rewards Points: 184
Doh!!!
Old 01-18-2015, 02:32 PM   #10
Rewards Points: 6
You'll need a helper. If you are sure the water is on to the solenoid. Remove the orifice from the solenoid. Turn the humidistat down so the solenoid does not active. Fire up the furnace and have your helper quickly turn up the humidistat so the solenoid opens and then down quickly. If you get a steady flow of water then the orifice is clogged. It's a tiny hole so it clogs easily. Earlier this season I thought my solenoid was bad when all it was was a clogged orifice.
Dan
djlandkpl is offline   Reply With Quote
Old 01-18-2015, 02:33 PM   #11
Rewards Points: 582
make sure your water valve is fully open...and make sure the orifice for the tubing going to water panel on humidifier is not clogged...
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
