-   -   Water in my furnace? (http://www.diychatroom.com/f17/water-my-furnace-2778/)
Jonboat 06-16-2006 11:37 PM
My wife turned on the AC while I was @ work when I came home she said the house wasn't cooling & when the ac came on it barely blew & would only run a couple of minutes. I went out to look @ compressor & the fan seemed to be working so I went to the furnace & noticed water leaking from around the fan @ the bottom I could also hear water leaking inside the furnace :eek: Anyone have any ideas??? We have a forced air gas furnace ( Magic chef Air ease) the central air is a janitrol also have a humidifier (Aprilaire)on the furnace. I just put 500 into a waterpump for our car now this.... please tell me this isn't going to cost big bucks!!!
redline 06-17-2006 08:16 AM
Is the fan (blower) turning inside the furnace?
The water may just be condensation from the a/c. The drain line may be plugged and just needs to be cleaned out.
Jonboat 06-17-2006 09:21 AM
water in furnace
I shut the a/c off last night ,I didn't want to take a chance of any further damage. I went down this AM turned it on the blower does work but only for about a minute or two then shuts off it comes back on a couple minutes later barely blowing. I can hear & see the water is coming out of the fan dont seem to be coming out of the hose that runs to a drain. There's a water line with a bigger insulated line running into the furnace that sounds like where the water is coming from. I really appreciate all the help I dont have a clue about these things!!
MAS2006 06-17-2006 10:49 AM
Check your return filter and replace if needed, make sure return is clear. Switch fan from auto to on at thermistat to check blower, some units have two speed blowers. The line from compressor should be warm, the insulated line returns coolant to compressor, cold to touch. AC pulls water from air, hence the drain pan and line. Turn off water supply to humidifier (only need for heating season).
coolmen 06-18-2006 09:37 AM
All this water is from when the out side a/c is on and if lets say a VERY dirty filter or bad indoor blower motor does not send air across the evaporater coil.this will freeze over and a block of ice will form.so much ice that it wont just melt back into the drain pan but drip around this and down into the furnace area/motor area.keep in mind that low refrigerant will make it freeze allso.A simple clogged drain may be the source as well.
Jonboat 06-18-2006 02:13 PM
When you say the filter, I assume you're not talking about the furnace filter, where would that be located? How can I check for a clogged drain? There doesn't appear to be any water coming out of the hose that goes from the furnace to a drain in the basement. There's an elbow the drain hose is connected to, do I need to remove that & inspect it for a clog? I'm thinking the blower is shutting down because of the water could that be ?
Jonboat 06-18-2006 03:34 PM
I just took the elbow off & a 6" X 18" piece of sheet metal to look inside. I couldn't see alot but the bottom ( drip pan?) looks wet & rusty. There was debris ( flakes of rust ) in the elbow but not enough to think it would cause a clog. There was also quite a bit of slimy looking residue in the drain hose. I cleaned both the elbow & hoses ,. I couldn't find the filter other than the furnace filter which looks new.
We ran the A/C several weeks ago noticed water coming out of the blower after some investigating I assummed it was from the Humidifier. I checked owners manual & seen your supposed to turn off water :o ( first time homeowner ,bought the house in Feb. ) supply to the humidifer so I did & it ran good the rest of week then it cooled back off so it 's been a couple weeks since it's been on.
I'm thinking I'll put the elbow& hoses back on then use a hair dryer on the fan to dry up as much water as possible that may be sitting in the bottom of the housing. Do you guys have any other suggestions that I might try before having to call someone?
Jonboat 06-22-2006 01:15 PM
Just wanted to Thank you guys for your help it did turn out the blower in the furnace was burned out & did just as you said it didn't blow across the coils causing it to freeze then the water overflowed the drip pan.Thanks alot!
Haro 07-24-2014 12:39 AM
water in bootom of furnace and water running from 1 of the 2 ports on AC
Coleman gas furnace- sounds like we are on the same topic.
I know I have relay that "sticks" keeping blower motor running when AC turns off. I suspect I need to replace board p/n 031-01267-001A, but before opportunity I heard blower running and went to check for sure. Found floor wet and opened face of furnace and found bottom tray of furnace filled with water. I noticed above furnace on stack that contains AC condenser (?) there are 2 ports. One has hose attached and other does not. The one without hose saw water spraying out when I manually turned furnace switch on and stopped when I turned furnace off. Obviously water has been running down inside furnace as I see rust on the trays inside furnace. Need help to understand what is happening and what to do to fix, beside replace board. I can not tell how many hours blower has been running with AC at set temperature.
jmon 07-24-2014 10:04 AM
If you don't get good suggestions/advice, it may be best to start a new post. This one started back in 2006. Sometimes members just scan the start date and if it's really old they just scroll down to next post. However, you may get good answers. Just a suggestion.
