Old 10-10-2006, 09:00 PM   #1
Water level in boiler system
We have water baseboard heat. Last winter we had a lot of noise, probably due to the low water levels. We found out that the water main to our house was clogged and our water pressure was next to nothing. The lack of water ruined our water heater.
It didn't seem to affect the boiler or heat system. However, I wondered if there's a way to know what the water level is in the baseboard radiators.
I turned the spigot that lets more water from the main into the heat pipes and we could hear it running into the pipes. I let a lot of water in (I think) then shut it off because I was afraid of letting too much water in.
Can I do that (let in too much water)? Is there a way to know if there's enough or not enough - without hearing the banging and clanging in the basement?
Thanks -
Barefoot Brian
Barefoot Brian is offline   Reply With Quote
Old 10-10-2006, 11:19 PM   #2
World famous jerk.
Holy cow.... STOP what you are doing.
A hot water heating system is "full" at all times. The difference is that there is a pressure reducing valve that limits the pressure to 12 or 16 pounds. If you pressureize your heating system to full city pressure, you'll have a royal mess on your hands. Your pressure relief valve on the furnace will start to puke water all over the basement, and your pipework (previously not used to those pressures) can declare it's leaks. Often, the bleeders will begin to leak too. I assume you used the "fast fill" lever on the pressure reducing valve when you did you test a bit ago.
Now... you might have a steam system too, with a "manual fill" valve, and you might not know you have steam and are confusing it with hot water. Does your furnace have a sight glass? (a glass tube about 1' long on the front where you can observe the water level). A steam boiler is only about 1/2 full of water.
mdshunk is offline   Reply With Quote
Old 10-11-2006, 08:21 AM   #3
What is the reading on the psi gauge?
redline is offline   Reply With Quote
Old 10-19-2006, 02:11 PM   #4
Thoroughbred Mopar Man
Hi Barefoot Brian
The first thing you should is listen to mdshunk, STOP! If you do not know or do not understand a hydronic or steam system they can be and sometimes are very dangerous. The easiest way to determine what you are dealing with is to look for the components that mdshunk described. The other way to tell a hydronic or a steam system is to look at the baseboard heaters. If the base board heaters are a coppertube with aluminum fins, its a pretty safe bet you are playing with hydronics. If they are made of cast iron or steal its a pretty safe bet you are dealing with steam. Do not confuse the two of them, they both use water but are totally different. On a hydronic baseboard if you pull the cover off there will be a little screw in one end, this is an air bleed. Carefully turn the screw counter clockwise. If water comes out shut the screw and go to the next one. If they all have water coming out your done. Check pressure gauge, make sure it is not reading above 16 psi. If it is you can either use the boiler drain or do yourself a favor and test the pressure relief valve.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
More On This Topic
Hey guys my name is J and I'm talking to you today on behalf of Expert Village. On this clip I'm going to show you how to heat a double boiler. Right now I've got my pan on high heat. What I'm going to do is get about four cups of water and you want to... Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Okay to make the coconut almond fudge we are actually going to set up a double boiler. Now you've probably seen me do this before. If you've ever been to the Baker's Corner, and basically means we're going to use an indirect source of heat. We don't want... Read More »
Now, a double boiler is very simple to do. You have to do it because it would be risky to put this chocolate in the microwave to melt it, because when chocolate burns, it does so almost instantly, and this way, over a double boiler, pretty much... Read More »
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
Hot Water Heating System Estimate Cost ? helpless handyman HVAC 45 12-26-2006 10:59 AM
Debugging Hot Water Heating System when on Standby Power hwitten Electrical 4 12-15-2006 09:47 PM
Bleeding air - Hot Water Boiler Dragon HVAC 10 10-30-2006 09:13 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
