Water Leaking From Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 07-07-2008, 01:31 PM   #1
Exclamation
water leaking from vent
I bought a condo a few months ago, and the roof was replaced in 2002. I had someone come out and reseal my skylights and looked at the roof and it was ok. Yesterday there was a horrible rainstorm and I noticed water leaking out of my ceiling vent. It rained very hard before and there has never been a leak, also the air conditioning unit had been running, so I thought maybe it had been condenstation, but that had never happened before either. Any ideas on how to figure out what is causing this?
Leanne
punkgrlie818 is offline   Reply With Quote
Old 07-07-2008, 02:24 PM   #2
Rewards Points: 150
got to get up there
New leaks are tough ,because there isnt alot of staining to trace back. Climb up in the attic and locate the vent that was dripping. Now you have to think like the water. look up for discolored wood above the vent , pull out the insulation next to the vent . water will travel sometimes a far way even over sheet rock to the best way down . It could be as simply as a crack in the drain , a break in the insulation on the ductwork . worse case its the skylight . hope not
geo fan is offline   Reply With Quote
Old 07-08-2008, 06:38 PM   #3
Phil
I don't know about your setup but usually the outer walls and roof are owned by the condo association in common and are the responsibility of the association and repairs need to be approved and conducted through the board. Check your situation and if it is their responsibility to fix you can file a claim for damage caused by the leak inside your unit (including dealing with a ceiling stain). Important to determine if they need to fix and to provide them with written notice as soon as possible of the problem.
Water travels and so where it is coming out is seldom where it is coming in. If it is from the air conditioner it is easy to verify that there is a condensate line and that it is still hooked up and not plugged with debris.
And then there is the issue of disclosure if this is a pre-existing condition that the prior owner failed to disclose. Neighboring condo residents may be able to comment on problems the prior owner had with regard to leaks.
Phillysun is offline   Reply With Quote
Old 07-09-2008, 06:40 PM   #4
Ouch!That'll leave a mark
Lightbulb
Was the entire deffuser wet? could just be that your humidity level inside the house was elevated with the rain storm and the cold air coming from the A/C condensed the air and made you assume the roof was leaking. How much water leaked? Buckets or Drops?
ridgevilleac is offline   Reply With Quote
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-02-2008 11:00 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 10:28 AM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 06:22 PM
