Water Leaking Under Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 09:01 PM   #1
Water leaking under Furnace
I have water coming from underneath my furnace. Help!!
dianekh is offline   Reply With Quote
Old 01-31-2012, 09:32 PM   #2
how
Rewards Points: 1,104
Start your own thread if you don't want your diagnostic confused with the person who started this thread!
how is offline   Reply With Quote
Old 02-01-2012, 06:34 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,626
Ayuh,... Hi Diane,...
We can't see it, so you've gotta Explain yer problem Much better than 1 sentence....
Btw,... a Furnace heats Air,... A Boiler heats water...
Which do you have,..??
Bondo is online now   Reply With Quote
Old 02-01-2012, 06:56 AM   #4
at this point if you can post a picture, it would be the best case scenario for us helping you.
harleyrider is offline   Reply With Quote
Old 02-01-2012, 06:57 AM   #5
Water under Furnace
I have a furnace. But there is water all around it on my basement floor. Help!1 Thanks
Old 02-01-2012, 07:05 AM   #6
since its the dead of winter, I am going to assume that its a condensate leak, from a plugged trap, or your humidifier has issues.
Old 02-01-2012, 07:31 AM   #7
furnace
Just need to know what to tell the Hvac person or to at least know how to speak with him. The humidifier is turned off so hopefully its a clogged drain. Can I pour bleach in the drain? If so Where do I find the pipe to do so?Its a Rheem probably 15yrs old. Thanks
Old 02-01-2012, 02:02 PM   #8
An old Tradesmen
Rewards Points: 7,802
Could be a cracked furnace trap, or a lot of other things. best way to find out what it is. is simply by looking for where it comes from.
If your going to have a tech find it. Simply show him where the furnace is, and answer any questions he has for you.
lennox elite furnace leaking water outboardhuy HVAC 10 09-24-2011 10:43 AM
No hot water from water heater unless the furnace is on karlmarsh Plumbing 3 06-08-2011 02:28 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
