Old 05-25-2012, 01:08 PM   #1
Water leaking from pipe under auto fill valve
I have water leaking from the pipe connected to and under the auto fill valve on my oil burner. Today the oil burner had stopped and I had no hot water.
Does anyone know what I should do to correct this problem?
Thanks!
George
gbeninghof is offline   Reply With Quote
Old 05-25-2012, 08:48 PM   #2
An old Tradesmen
Post pic, so we know what pipe it is.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Hot water tank leaking from valve pipe bookingohio Plumbing 11 05-07-2009 10:43 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
