Water Leaking Out Of Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 02:34 PM   #1
water leaking out of furnace
I have a 20 yr old unit. Sits in room off back of kitchen. Noticed water on the floor. The water is condensing & dripping down off the copper tube that runs under the house to the outside unit. There is a red drain plug there so sure enough I opened it & water came out. Replaced plug but it still dripping. What is the bad news?
picklerose is offline   Reply With Quote
Old 07-03-2011, 02:56 PM   #2
Rewards Points: 6,652
Your drain line is clogged to let the water out of the pan, that sits between the furnace & A-coil.
Old 07-03-2011, 03:23 PM   #3
Is this a "DIY" project or am I going to shell out some $$$ for someone to look at it?
Old 07-03-2011, 04:57 PM   #4
It is as long as you do not create a problem unclogging the drain, or find out that the A-Coil is iced over, when you take the cover off of the ductwork where the A-Coil is sitting. You are welcome to post pic's of the furnace, if wanting to know where to look.
lennox elite furnace leaking water outboardhuy HVAC 10 09-24-2011 10:43 AM
No hot water from water heater unless the furnace is on karlmarsh Plumbing 3 06-08-2011 02:28 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
