Water Leaking Into The Furnace When AC Is On - HVAC - DIY Chatroom Home Improvement Forum
Old 09-24-2012, 10:00 AM   #1
water leaking into the furnace when AC is on
Did the water that leaked into the furnace from a possible clogged drain pipe when the ac was on damage the furnace?
Kingslp is offline   Reply With Quote
Old 09-24-2012, 04:00 PM   #2
biggles's Avatar
over a season it could start to pin hole the heat exchanger cycle the heat to dry off and burn off any mold & muck......sitting at the furnace as the cycle comes up after the burner lights note the shape of the flame and when the supply fan kicks on see if it waves flutters.....
Old 09-24-2012, 06:03 PM   #3
Probably not. Usually the water doesn't hit anything but it can cause problems with electronics if it ran on them.
Old 09-24-2012, 06:06 PM   #4
An old Tradesmen
Rewards Points: 6,550
If its still working, probably not. if it was only a one time thing for a short period of time.
lennox elite furnace leaking water outboardhuy HVAC 10 09-24-2011 11:43 AM
No hot water from water heater unless the furnace is on karlmarsh Plumbing 3 06-08-2011 03:28 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
