Water Leaking Furnace Heat On - HVAC - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 12:09 AM   #1
Hello everyone, I recently notice that water was starting to form around my Furnace in the basement and this is when I have the heat on. I'm not sure how old the furnace is but I think it's pretty new. During the summer when we had the air conditioning on it never leaked any water and for the most of this winter It has not leaked until recently. I did a visual inspection of the drain pipes but I do not think it is leaking from a cracked pipe. Any ideas of what maybe going on and I thank you in advance.
-Aaron
Anarchy1505 is offline   Reply With Quote
Old 03-07-2010, 07:07 AM   #2
Licensed Master Plumber
Need pictures.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 03-07-2010, 07:12 AM   #3
where are you, roof leak?
The older I get the better I was
Old 03-07-2010, 09:54 AM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
is it a 90plus furnace? check drain lines
plummen is offline   Reply With Quote
Old 03-07-2010, 01:54 PM   #5
Furnace Leaking
The roof is new. I think it's where the water drains out of the pipes. And I am not sure what a 90plus furnace is. Here is some pics of the furnace leaking downstairs.
-Aaron
Water Leaking Furnace Heat On-pict0006.jpg   Water Leaking Furnace Heat On-pict0007.jpg   Water Leaking Furnace Heat On-pict0008.jpg   Water Leaking Furnace Heat On-pict0009.jpg
Old 03-07-2010, 01:58 PM   #6
plummen's Avatar
90 plus furnace uses pvc pipe instead of metal flue pipe
Old 03-07-2010, 02:01 PM   #7
Looks like the condensate line has a leaking fitting. Make sure they glued the fittings, sometimes the installers get sloppy. Other than that it could be an improperly pitched flue pipe or the furnace is not level and the condensate is running out the exchanger instead of out the drain.
Old 03-07-2010, 07:42 PM   #8
Furnace Leaking
Yes it is a 90 plus furnace. I will check out the drain lines to see if the fittings are good and glued. Do you think it is a good idea to open the furnace up and see If I can see in to see if the exchanger is the source? Again thank you in advance.
-Aaron
Old 03-07-2010, 07:48 PM   #9
plummen's Avatar
sure you can open the front cover of furnace to make sure controls and board are not getting wet,you wont be able to check heat exchanger just the drains from it and inducer motor and maybe bottem of flue pipe depending on plumbing
Old 03-08-2010, 01:42 PM   #10
Newbie Bill
Rewards Points: 522
We had the same problemm on our high efficiency furnace. The furnace company came out and opened the front door of furnace. The leak occurred at the joint between the furnace and the small plastic drain pipe. He just tightened it up and all was good.
It would have been an easy DIY thing, but the furnace was still under the installation warranty so it didn't cost me anything for 3 minutes of this person's time.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Need help with heat and hot water issue Spydey HVAC 50 03-07-2010 08:46 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 03:23 AM
Burnham V-7 furnace leaking water Fastlane HVAC 7 11-29-2008 07:34 AM
York Furnace Leaking.. Please help sidoe HVAC 4 10-08-2007 04:55 PM
