Water Leaking From Boiler.. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-15-2010, 04:26 PM   #16
An old Tradesmen
Rewards Points: 6,544
More water in the tank, will make the relief water open quicker.
The tank needs to be isolated from the system, then drained of ALL water. then the system reopened to it.
Most likely. The tank was already too full of water. And your rads had air in them. And they were acting as the expansion tank. And after you refilled your system. the water now has no where to expand to.
Old 11-15-2010, 05:02 PM   #17
Rewards Points: 150
You can get water directly into solution with no o2 barrier, that is exactly happened to me except it was my hole entire second floor.
One suggestion he might be able to do, rent a pipe freezer and isolate that way. Obviosly turn off the burner and have all the connection made up. Never tried it.
ianc435 is offline   Reply With Quote
Old 11-16-2010, 05:08 PM   #18
Rewards Points: 150
Yes cap the line. The blader could be moved over to the elbow to the right. 3 way t 3/4 npt male 3/4 ball valve then bladder. Isolation is a must because they do go bad. Plus that pipe lookes faily rigid and it would look cleaner there, just my opinion. Don't think depot carries those, heating/plumbing supply store if they will sell it to you. About 40$. You will have to drain you sys tem but no the boiler. While younhave it mt, isolate your rads and t the off so you cann fill the i use boiler valves.
Old 11-16-2010, 06:12 PM   #19
Retired Electrician
Home depot carry them
fy171 is offline   Reply With Quote
Old 11-17-2010, 12:47 AM   #20
Rewards Points: 115
Thanks for the info!!
If it's not to much trouble do you think you can sketch me a diagram?
Also what's killing me is that I totally drained the system, next thing I know it refilled, gauge is past 30 & that pipe is dripping? How is this thing refilling??
Carloscda is offline   Reply With Quote
Old 11-17-2010, 04:56 AM   #21
An old Tradesmen
If you totally drained the system. Then you have/had the boiler turned off?
The PRV is probably leaking if you totally drained the system, and it refilled.
Pressure Reducing Valve.
Old 11-17-2010, 05:14 AM   #22
Rewards Points: 150
If you used the ptv to draon the system you could have sediment on the seat of the valve or it could have erodedthe rubber orings and thats why it is leaking. But that being said you need to replace the exspansion at some time. It is old and less trublesome. In the picture it looks like you replaced a pt already?
Old 11-17-2010, 02:22 PM   #23
Rewards Points: 115
First off I would like to thank everyone for helping me on this!!
Is are some better pics & I noticed the connection under the pressure relief valve is split so I'm going to replace that whole connection.
Now this pressure reducing valve, where is that located?
Old 11-17-2010, 05:02 PM   #24
An old Tradesmen
It will be on the cold/fresh water feed pipe.
Old 11-17-2010, 05:19 PM   #25
Rewards Points: 115
The only feed is that one to the left?
Old 11-17-2010, 05:27 PM   #26
Rewards Points: 150
I dont see a prv any where in the pictures. You have a handle valve near the tank tee in to the 3/4 copper. , what is that for. Secondly you should put a back flow preventor in case of city water loss off pressure and you boiler dumping into you drinking water.
Try hanging the tank to the right of wher you want to closer to the radiator riser. At least the that is going up will give it a little more support than directly in the middle of the pipe. Don,t forget to ball every thing you can. Read my earlier post. Hey, good luck.
Old 11-17-2010, 05:28 PM   #27
An old Tradesmen
Which one is the one to the left.
Old 11-17-2010, 05:28 PM   #28
Rewards Points: 150
Is that the one right on top of the water heater?
Old 11-17-2010, 06:59 PM   #29
Rewards Points: 150
Here are pictures of stuff. Prv fill valve 1st, second is back flow preventer before prv, and third is where i hung the expansion tank. Notice the rusty china made pipe from home depot/china. Never again. Next time a header.
Old 11-17-2010, 07:25 PM   #30
Rewards Points: 115
@ianc435... I don't have any of those valves? Do I need to install them?
beenthere... That's the only water feed on the system.
boiler and hot water venting AdamBNYC Plumbing 3 08-26-2010 06:09 PM
Leaking Water Heater (from Cold Inlet?) doesntmatter Plumbing 7 07-12-2010 10:30 PM
Coverting from Steam to Hot water Boiler ericm215 HVAC 1 05-23-2010 11:03 PM
Hot Water Heater Leaking From Top jim.flack Plumbing 3 01-13-2010 05:56 PM
HVAC Unit Leaking Water timb10594 HVAC 1 08-26-2009 10:51 AM
