Water Leaking Around Furnance Flue - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 03:43 PM   #1
Water leaking around Furnance Flue
Hello, I noticed that there is some water that is leaking in frm the outside of the furnace flue.. I went in the furnace room yesterday and i noticed a big pile f water on the ground.
My furnace is new- we got it about a month ago..... what could it be?
jo_c is offline   Reply With Quote
Old 01-25-2012, 04:26 PM   #2
HVAC Tech/ Browns Fan
Call the company to come back out. Must have a pvc joint leaking.
Tator1076 is offline   Reply With Quote
The Following User Says Thank You to Tator1076 For This Useful Post:
harleyrider (01-25-2012)
Old 01-25-2012, 04:39 PM   #3
when you say flue that means a chimney. Did you have an 80% furnace installed or a 9% furnace which vents with PVC pipe.
If it was an 80% than did they put a liner in the chimney? No liner= condensate water on the floor.
hvac5646 is offline   Reply With Quote
Old 01-25-2012, 04:44 PM   #4
do not touch a thing............call the company that put it in, back out.
harleyrider is offline   Reply With Quote
The Following User Says Thank You to harleyrider For This Useful Post:
ben's plumbing (01-25-2012)
Old 01-25-2012, 09:08 PM   #5
Rewards Points: 582
agree with harley don't touch it ...call company back something wrong with install if only a month ..may be simple or more complex...
Leaking Pipe above hot water heater with pics notarock Plumbing 9 07-30-2011 09:29 PM
Water Leaking into Garage ghostee Building & Construction 2 06-11-2011 08:20 AM
HELP: Lennox C33-36C-2F leaking water hamproof HVAC 33 06-26-2010 03:48 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-03-2008 12:00 AM
