Water Leak Carrier 90% Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 04:16 PM   #1
water leak carrier 90% unit
I have a carrier 90% furnace and is leaking water which seems to be behind the draft inducer motor but not sure it is leaking into the blower compartment. any thoughts? i checked the primary drain line and it is clear
cheld is offline   Reply With Quote
Old 01-11-2011, 07:06 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
how old is the unit?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-12-2011, 01:00 PM   #3
2 years old
Old 01-12-2011, 02:45 PM   #4
AKA HVACTECHFW
if you dissasemble it it will need re siliconed. It should be under part warranty ie No Labor
IT IS WHAT IT IS
Old 01-14-2011, 06:18 PM   #5
carrier 90% furnace
I called carrier and found out that the unit can not be level and has to be proped up a quarter of an inch toward the door when the unit is horizontal. i did that and the unit works beautifull. thank you for all your help.
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Water Pipe Leak in Backyard diginside Plumbing 2 07-08-2010 04:50 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
carrier 9200 furnace water leak maryjo HVAC 5 11-26-2009 06:58 PM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 10:07 AM
