Water Leak - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2015, 01:42 PM   #1
Water leak
I have an older home 1948 with a newer furnace. I seem to have water bleedung through the concrete about two feet below where the metal pipe connects into the chimney. I have a new filter in it just not sure.why the wall is bleeding
hughrsponar is offline   Reply With Quote
Old 11-05-2015, 04:17 PM   #2
An old Tradesmen
Rewards Points: 6,148
Made this its own thread.
Old 11-05-2015, 08:19 PM   #3
how
Rewards Points: 1,070
Condensate in the chimney from the furnace???
Is the chimney on an outside wall?
Is the vent into the chimney single wall or double?
Do you have a liner in that chimney?
Is the space between the furnace chimney vent and the chimney wall open at the top of the chimney?
What kind of furnace do you have? Btu's on the rating plate? Overall height of the chimney and the size of the furnace vent pipe? Length of the furnace vent between chimney and the furnace? Inside diameter of that chimney?
Do you have an old chimney clean out, outside that is open?
Is the furnace room kept cold?
how is offline   Reply With Quote
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 02:56 AM
Plumbing Leak Distorting Latex Paint into Bubble, Evidence of HOT Water? Lovegasoline General DIY Discussions 10 08-29-2013 02:27 PM
Fixed water leak now low pressure whitecrow Plumbing 15 08-13-2011 12:36 PM
Copper Pipe Leak Caused by Hard Water? Asathd Plumbing 20 07-09-2011 10:06 PM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 10:24 PM
