Old 08-09-2008, 09:28 PM   #1
water on HVAC ducts
I was under my crawl space today and saw/felt water in a few spots on my HVAC ducts ( I have a package unit outside house) Is this condensation and normal? Thanks
ugabulldog is offline   Reply With Quote
Old 08-10-2008, 05:42 AM   #2
oops, did I do that!
water on HVAC ducts
Yes it is probably condensation. Ductwork should be insulated, on the inside, or outside to prevent this. Wrap the areas with fiberglass, and tape the ends. If left unattended it may cause a musty smell in the ductwork.
8 Ball is offline   Reply With Quote
Old 08-10-2008, 10:21 AM   #3
water on HVAC ducts
it is insulated and taped but the water is still seeping through.
Old 08-11-2008, 05:53 AM   #4
water on HVAC ducts
Is the insulation tight on the duct or loose. Somewhere warm air is making contact with cold air. A small amount of moisture is not unusual during an extended period of warm weather, but once the insulation is saturated, it is not insulation any more, it becomes a conductor.
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
