Old 02-18-2008, 02:49 PM   #1
Unhappy
Water in heating vent
So my 2nd story bathroom was flooded, resulting in water pouring down into my heating vents. I turned down the furnace for now until I knew what effects the water might have, but can't find any info about it on-line. My gut instinct says that it's fine, or they would have some kind of codes on how vents have to be installed in places where water is around (bathrooms, kitchens, laundry rooms, etc.). My gut instinct, however, isn't always right. Can anyone help me out with this? Thanks!
pbberk81 is offline   Reply With Quote
Old 02-18-2008, 04:32 PM   #2
It's hard to guess how much water got into the duct. You may have some that is laying on horizantal runs. I believe the only thing you can do is to run the furnace fan on high and shut down the humidifyer. Any water left in the duct will evaporate much quicker. Check the furnace blower area and around the electronic controls for water. If they are dry, then you are ok there.
Any water in ducts will evaporate in time.
rjordan392 is offline   Reply With Quote
Old 02-18-2008, 05:26 PM   #3
Have you look at the furnace area to see if there is any substantial amount of water there?
redline is offline   Reply With Quote
adding water to heating system stonegirl HVAC 1 12-17-2007 12:53 AM
New To Hot Water Home Heating System Midicat HVAC 2 10-14-2007 09:12 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 11:28 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
