Water Heater Won't Light - HVAC - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 02:12 PM   #1
Water heater won't light
I have a 6 year old AO Smith propane water heater, model #GPSH 50-101. The heater wont light by itself and shows an error code that the system is in lockout.If I unplug the unit from the wall and plug it back in it tries to light 3 times and shuts itself off and shows the same error code.If I unplug the 3 wires that go to hot surface ignitor and sensor and plug them back in,it will light and work great. Do I need to replace these parts or could it be something else?
adfuhrer is offline   Reply With Quote
Old 12-10-2010, 02:59 PM   #2
Try polishing the sensor with steel wool or a scotchbrite pad. Don't use any type of chemical cleaner.
SKIP4661 is offline   Reply With Quote
Water heater won't light adfuhrer Plumbing 0 12-10-2010 02:11 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
Pilot Light Won't Stay Lit on Water Heater jdolan HVAC 4 07-23-2010 04:42 PM
Replaced water heater, still smelling sulfur in hot water & Low water pressure aminus21 Plumbing 2 07-21-2010 04:40 PM
Problems with water heater jwise Plumbing 11 02-26-2010 07:36 PM
