Water Heater In Unheated Utility Room - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 08:33 AM   #16
Roofmaster
Rewards Points: 2,210
Makeup Air
I defer to the HVAC pros on the makeup air, but just out of curiosity, How can I have a vent free gas log, and a gas stove with no flue bburning inside the house without problems? Are they that much more efficient than a gas water heater?
Also, If you have a gas water heater in your basement, and say you have two bathroom exhaust fans running, pulling negative pressure on your home, how is that different from having a separate room that uses ambient air for combustion?
Im asking because Im interested, not to buck the code.
My dad always said that its no good to have a house thats too tight, and now I believe him.
Old 12-13-2012, 08:51 AM   #17
Missouri Bound's Avatar
Amazon.com: Easy Heat EH-38 Freeze Thermostatically Controlled Valve and Pipe
Not too sure if I am onboard with the light bulb idea....but I grew up in the Chicago area and my dad had a light in the pump house for several years. As I child my friends and I would play in there in the winter and it was always much warmer than the outside temp...even when well below freezing. Anyway, these devices are used here just about everywhere in the pump houses with a small heat lamp. It's just something you need to check at the beginning of each winter season.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
momof2labs (12-13-2012)
Old 12-13-2012, 09:18 AM   #18
Roofmaster
Heat Pump???
Here I am Visualizing a water heater tank standing in a separate room. Pictures really are very helpful, or at least a description which has all the basic information. Geeeeeeeeeeez! SO much for assumption
Old 12-13-2012, 10:54 AM   #19
Items wanted: Time
Rewards Points: 150
Super tight homes, .5 air changes per hour or less, will have problems, not so tight homes will not. Your second point, it's a world of difference, heater in basement w/exhaust fans, again in tight construction that exhausted air will be made up somewhere, hopefully not through the flue. Same goes for sepererate room, the exhaust needs to be replaced or eventually the appliance will not vent.
NiNe O is offline   Reply With Quote
The Following User Says Thank You to NiNe O For This Useful Post:
jagans (12-13-2012)
Old 12-13-2012, 01:42 PM   #20
Rewards Points: 87
I am not there but in the process of moving there. (Very soon). The room is about 6 x 6 and contains the electric panel, 3 water treatment tanks and a furnace(?). I'm going from memory.
momof2labs is offline   Reply With Quote
Old 12-13-2012, 08:11 PM   #21
Roofmaster
Pictures
When you get there, take some pictures and let us know how that heat pump breathes.
Old 12-14-2012, 02:36 AM   #22
An old Tradesmen
Rewards Points: 8,170
Might be that you have problems but just don't know it yet. Gas ovens are permitted to put off up to 800PPM CO. They are not very efficient.
Put a high end CO detector above your stove or oven and it will alarm quickly.
Your house may have a higher leakage rate then you realize. Could be over 1 ACH.
Old 12-14-2012, 03:31 AM   #23
Domestic gas ranges are only allowed to put out 500ppm here, and that is from an undiluted flue gas sample (ie taken before the flue gas leaves the appliance).
Placing a CO detector/alarm too close to a gas appliance could give a false high CO reading. Follow manufacturer's suggestions.
This Christmas I am on standby and fully expect to be called out for at least a few CO calls: cooking all day on a gas range will lead to a build-up of CO on a detector and necessitate a visit from the gas company to ensure that here is no real problem. This is almost guaranteed. But, this is what I do, and safety us paramount, so if you suspect CO is present, or smell gas, CALL YOUR GAS COMPANY!!! I would rather go to a million false calls than one real CO/gas odour call with a fatality/sickness. Stay safe this Christmas!
hvac benny is offline   Reply With Quote
Old 12-14-2012, 05:01 AM   #24
An old Tradesmen
Placing a detector close to the range/oven was just to show him how in-efficient his range/oven is at burning gas.
ANSI standard is 800PPM AF(0.08%). UL is much lower(probably the 500 you said).
Old 12-14-2012, 05:25 AM   #25
Items wanted: Time
Rewards Points: 150
Deleted
Tags
unheated utility room , uninsulated water heater , water heater jacket
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
Water heater for upstairs guest room in barn minduhla Plumbing 2 10-11-2009 04:14 PM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
