Water Heater Is Gushing Water To The Outside - HVAC - DIY Chatroom Home Improvement Forum
Old 12-14-2006, 11:38 AM   #1
water heater is gushing water to the outside
i bought a home recently and had the gas turned on yesterday. the water heater was on about 2 hours and i noticed the water wasnt very hot. then i noticed the relief valve pipe that runs to the outside was gushing hot water. i've read some of the posts in here and i believe its a pressure issue? are there any simple things i can do to fix this before i spend money and have somebody come out and look at it? thanks.
ckcrew is offline   Reply With Quote
Old 12-14-2006, 12:13 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi ckcrew
If you have a pipe wrench, some time and about $25.00. You can do this project without a great deal of trouble. You will need to replace it with the exact same rated piece. If you can take it with you to the hardware store, they can make sure you get the proper one.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
