Water Heater Control Unit Makes Noise Then Shut Off... - HVAC - DIY Chatroom Home Improvement Forum
Old 12-23-2009, 10:00 PM   #1
Rewards Points: 408
Water Heater Control unit makes noise then shut off...
My water heater is a big blue tank next to my boiler and the only thing I could scrape off it was the name Amtrol. A couple of weeks ago the repair guy came to fix some parts on the boiler(electrical) and he noted that the relay was making a noise which I said it had never done before. It went away so we though nothing of it but over the past couple of days it's been back and I traced it down to the control unit on the hot water tank. I jiggled the wire going into it and the lcd screen went blank. Usually this screen has some numbers on it so I'm guessing the unit died. I just went down again and jiggled it some more and the noise came back but the LCD screen is still off. So, my questions are.
- Is there any way to force it to heat without this so I can get hot water?
- Could this be related to the repair a couple of weeks ago?
- How can I test if the unit is bad or maybe it's a loose wire? The noise makes me feel like the unit is broken.
- I tried to Google the numbers of it but I came up empty, where could I find a replacement unit for this
RyanD is offline   Reply With Quote
Old 12-23-2009, 10:14 PM   #2
An old Tradesmen
Rewards Points: 8,234
Check to see if any of teh wires are loose.
Can't make hot water if that control is bad.
Old 12-23-2009, 10:46 PM   #3
The trick is to find a single connection that makes the screen go and come back when you wiggle the wire going into it. Tapping with a pencil may also cause the problem to show itself.
If the wires are bundled you may have to temporarily unbundle them.
It may be related to the repair, or a coincidence. If the relay is buzzing it also points toward a loose connection. If you have a schematic it might help if you post it.
Tags
hot water amtrol tank
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
Gas Hot Water Heater - Help? MaximumAsh Plumbing 22 03-13-2009 10:57 AM
Electric water heater noise mc73 Plumbing 1 05-22-2008 09:57 AM
water heater noise boman47k Plumbing 5 11-28-2007 06:31 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
