Water Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 04-18-2008, 02:51 PM   #1
Rewards Points: 16
Water heater
I posted this in the plumbing forum and have a lot of reads but no replies, so I thought I'd try here. I have a 9 year old Bradford-White power vent water heater. It uses the Honeywell "smart valve" gas control. The ignitor glows properly and the pilot then lights OK, but the main burner will rarely light on the first try. It sometimes will make the maxiumum 5 attempts and then cut out for a while. There is a flame sensor rod which appears to be in the pilot flame OK. Any ideas?
paulny20 is offline   Reply With Quote
Old 04-18-2008, 05:17 PM   #2
HvacWiz's Avatar
Rewards Points: 252
The gas valve needs replaced, these valves are famous for failing.
HvacWiz is offline   Reply With Quote
Old 04-18-2008, 09:18 PM   #3
Rewards Points: 16
Water heater
Thanks WIZ. It looks like the valve screws into the tank. Is this a DIY project, or should I get a pro?
Old 04-18-2008, 09:34 PM   #4
HvacWiz's Avatar
Rewards Points: 252
You should be able do do this yourself, if you have 2 pipe wrenches and some pipe dope you should be all set, if you dont feel comfortable with it I would suggest calling someone.
Old 04-20-2008, 06:45 PM   #5
Rewards Points: 16
I'll give it a try. Am I correct that the valve screws into the tank?
Old 04-20-2008, 09:24 PM   #6
HvacWiz's Avatar
Rewards Points: 252
Yes it does. Good luck
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
