Water heater
As long as the structure meets the building requirements, fresh combustion air requirements and the heater is vented properly you will be all right. I had a remodel done on my home several years ago and the boiler and water heater were outside during 1 month of freezing weather. Nothing froze up, the pilot never blew out on either device. Only a tarp covered the equipment. New water heaters do not radiate much heat so you may consider installing a small electric heater for freeze protection....although you may get some help from any hot water piping in the room. And I agree with staying away from tankless.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
