water in heat vents
Hi Donna, I think it may make sense to turn off the furnace at the breaker, then mix up some hot water and bleach in a bucket and pour it down into those ducts. Let it sit for a while then wet vac it out. Im thinking it would be a good idea to kill any mold you have growing down there. Once you have it dried out pretty good I would leave the blower running all the time on your furnace. Just turn the fan to on. You also want to clean out your condensate lines and trap if you have a high efficiency furnace. Maybe water is flowing out of the furnace because the trap is blocked with debris.
Go to your furnace and remove the lower and upper doors, they usually just lift up and out, and send us a picture of what you have.
How much water are we talking about?
" A lot of men build things, and a lot of things fall down "
