Water In Furnace Pump? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-30-2008, 04:06 AM   #1
Water in Furnace pump?
Remodeling my home. Currently sleeping in the basement, I awoke around midnight because the furnace was making an unusual noise. It's a forced air, gas system. I turned it off and took off the panels for inspection. It's a Lennox that is only about 6 years old.
There is a air pump(?) that is connected to the condensation drain and the PVC pipes that exit the roof. I assume that this isn't the blower (it seems a bit small and it's connected to the aforementioned roof exhaust and intake).
It sounds like this smaller blower has water in it. When I turn the system on and this pump turns on-it is the source of the noise. When it's winding down I can actually hear the water sloshing around in there. I thought that there might be a clog-preventing the draining of the condensate water? So I removed the easy to get to lines and drained and cleaned them (they were a little dirty). I thought that would fix it, but the was still doesn't seem to be coming out.
We've had some really cool and wet weather recently. I'm guessing the next step would be to remove this pump entirely for inspection? Any insight would be appreciated, thanks.
jabbakahut is offline   Reply With Quote
Old 12-30-2008, 05:46 AM   #2
An old Tradesmen
Rewards Points: 8,174
Trap may be clogging.
Old 12-30-2008, 06:44 AM   #3
Well I took it off and dumped about a cup of water out of it. I've checked most of what I can for clogs, didn't find much. It's running again, but now I'm not sure if I'm being paranoid about hearing a noise still.
Old 12-30-2008, 06:53 AM   #4
An old Tradesmen
Vent systems that go throught the attic to penetrate the roof, have more condensation then side wall systems.
So you will have some water getting back to the inducer.
Exspecially, without a drip/drain tee in the exhaust pipe.
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 08:01 AM
Sump pump pit water level Ralph123 Building & Construction 6 07-24-2008 05:33 AM
Converting from furnace to how water heater skittlzski Plumbing 2 05-16-2008 10:10 AM
Water around my steam furnace Volsar HVAC 1 12-11-2007 06:40 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
