Old 09-12-2007, 09:06 AM   #1
Default Water in Furnace
I have an Amana side-mounted furnace and yesterday I found a significant amount of water under and around the blower. Its been a hot summer and I've been running the A/C. I suspect its from there. Help!!!!!
nrtripp is offline   Reply With Quote
Old 09-14-2007, 12:03 AM   #2
Kyle Emerick
kemerick's Avatar
I would remove the water mess and see if it continues to fill up without running the unit. If so the water leak is coming from the line that feeds the unit. That most likely would require you to sweat a fitting or two+.
If it only leaks when the unit is running, it is the overflow/exhaust or whatever it is called. When the unit runs it will need to get rid of the water it creates or does not use. If the later is the case, then it should be PVC and you can just use PVC to fix it.
During my remodel I had a bucket under mine until it got its connection completed... and it filled almost a gallon bucket per hour.
My constant project is my home which was built in 1947. I have remodeled almost all of it and am in the process of finishing off a 1000 square foot addition. Lars Construction got me up to drywall and I am doing the rest.
You can see many galleries of it located here under Galleries and then House.
kemerick is offline   Reply With Quote
Old 09-14-2007, 01:17 AM   #3
jproffer's Avatar
There's no water feed line to a furnace.
It's run off from the A/C, plumb it to a drain or get a bucket.
jproffer is offline   Reply With Quote
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Hi, my name is Ed Reyes with Master Builders here in Tampa, Florida and I am representing Expert Village. We are going to show you how to use a reciprocating saw properly. There are different reasons why we use this particular reciprocating saw. In... Read More »
This step is called hand milling. Some people call it French milling others call it rebatching. What we are doing is we are taking the soap that we made earlier. It is cured enough to be hard and grate real easily and we are breaking it up any little... Read More »
A boat leak can cause expensive damage to your boat and all of the items that you keep in it. It's important to quickly plug your boat leak to avoid further damage to your boat and to keep water out. Follow these instructions to help you identify the... Read More »
water leaking out heating furnace eazacon2001 HVAC 17 01-21-2008 01:54 PM
water coming out of my furnace hmsmc1009 General Discussion 4 07-15-2007 12:53 AM
Water in Furnace Jerry Myrick HVAC 5 11-17-2006 06:26 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
Water in my furnace? Jonboat HVAC 7 06-22-2006 03:15 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
