Water Filled Gas Furance Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 09:26 PM   #1
Water Filled Gas Furance Not working
Hi everyone, maybe someone can help.
It's a Smith Cast Iron Boiler. Furnace stopped working this morning. Had same issue before, and worked now stopped working again.
When I turn off main switch to furnace than turn back on. The pump turns on and is working, than the pilot starts to light up(glow) and once it reaches a certain point a click goes off and light goes off(pilot dims). This cycle just keeps repeating.
I think its the gas valve is messed up not letting gas in. I made sure gas valve is in ON position and main gas pipe is on. Any ideas?
szym0n is offline   Reply With Quote
Old 02-21-2011, 04:46 AM   #2
An old Tradesmen
Rewards Points: 7,278
Tripped roll out switch.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Water Dispenser Stopped Working dgoldb1 Appliances 20 05-16-2011 05:48 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
