Water Is Dripping From Vent Pipe - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 09:37 PM   #1
water is dripping from vent pipe
I bought a foreclosed house. I had my guy come in and start up the furnase. I have noticed water, condensation?, dripping from the tin vent tube that attaches into the chimney in the basement and out the roof. What would cause this? Is the chimney clogged and not allowing the heat to vent?
klaus135 is offline   Reply With Quote
Old 11-30-2011, 09:40 PM   #2
biggles's Avatar
same as a car tail pipe when you see water dripping out it 's condensation
Old 11-30-2011, 09:42 PM   #3
Rewards Points: 582
My guess its and 80% furnace tied into a chimney without a flue linner....pictures would help....but as you said its dripping there condensation going on.. and yes it could be clogged why didn't furnace guy check that?? should have done complete safty check .... just thinking could be draft hood furnace too....
Old 11-30-2011, 09:43 PM   #4
Rewards Points: 12,818
Could be many things. Since it was a forclosed house I'd guess no ones been there for a while and there was little if an maintance done before.
No cap on chimmney and there's been rain coming in, condinsation built up in the pipe ect.
If you can see water dripping then carbon menoxide can also leak out of that pipe.
Old 12-01-2011, 03:00 PM   #5
Chicago, IL
Michael Thomas's Avatar
If it's a foreclosed house, birds or animals may have bee nesting there. The chimney could be partially blocked - a very substantial hazard.
These guys were living in a chimney venting both a water heater and a furnace:
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 12-01-2011, 03:19 PM   #6
Do I call back my furnase guy, or a chimney sweep?
Old 12-01-2011, 05:41 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
I would call your guy and have him inspect the chimney with a mirror and explain to him about the water and have him find out why it is happening. No point in getting a chimney sweep when there may be nothing wrong with it. If it is an unlined chimney or the area where the venting is is COLD then it may be sweating /condensing the moisture in the flue gases(smoke)and that will rot out that pipe and create a hazard. we use B vent, 2 wall pipe from the furnace to the chimney for that reason and to meet the code.
Old 12-01-2011, 06:49 PM   #8
Thanks for the responses. I did call my furnace guy back. He stated it will drip water cause it is an unlined chimney, which he stated was common with older homes. He stated the chimney is not blocked because there is a pressure switch in the furnace that would be tripped if it was not venting properly. He said I have to live with it unless I but a liner in the chimney. True?
Old 12-01-2011, 07:15 PM   #9
Hvac Pro
yuri's Avatar
code now says you must have a liner. the moisture will eat out the mortar between the bricks and it will collapse. having a pressure switch is NOT a 100% guarantee you won't have a dangerous condition. it can fail/be inaccurate.
grandfather clause allows those old installs but that does not make them safe. they found these problems later and changed the code but those are still grandfathered in.
Old 12-01-2011, 09:25 PM   #10
Ok, thanks. Is putting a liner down the chimney a DIY project? I have been doing all my own rehabs and can figure out just about anything. I have never seen a liner, is it just a matter of putting 6 inch tubes down the chimney untill I reach the bottom and then attach the 4inch furnace vent tube?
Old 12-02-2011, 12:18 AM   #11
how
Rewards Points: 1,070
A flexible continuous chimney vent that goes from the top of the chimney all the way down and into your furnace room will be your easiest route. Is the chimney on an outside wall or not? Do any other gas appliances use this chimney? Do you know the total Btu's of all the appliances that will be using this vent? Do you know the total height from the top of your furnace to the top of the chimney? You will also need a method of securing the chimney vent at the top of the chimney.
Yes it's a possible DIY job but you should educate yourself about it first and have a friend available to help you feeding it down the chimney.
how is offline   Reply With Quote
Old 12-02-2011, 12:49 AM   #12
how
Yuris post about using b vent between the furnace and the chimney should be paid attention to.
I've seen monoxide calls from rust perforated single wall vents on mid efficiency furnaces inside of the first four years of operation..
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 06:17 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
