Water Dripping From Heat Vents - HVAC - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 09:28 PM   #1
water dripping from heat vents
I have water dripping from the ceiling heat vents in bedroom and bathroom, I havent used the furnace in about 3 years I heat with electric heat now. The ducts are the flex type. I took the vent down yesterday as it had dripped all over my bed and i didnt realize it since i was at work...it was full of water, i stuck my hand up into the hole in ceiling, only the actual vent stuff was wet, can condensation build up in the flex ductwork if it hasnt been used in three years? THis is the first time I have had this problem!
Thanks!!
pamleo is offline   Reply With Quote
Old 01-28-2009, 09:37 PM   #2
JohnH1's Avatar
Could be nice warm humid air coming in contact with a cold register and boot cold from the attic and swetting. Dont know why this is happining now has something changed in the home?
JohnH1 is offline   Reply With Quote
Old 01-28-2009, 10:06 PM   #3
We had a new roof put on this fall, other then that its the same old house that needs alot of work lol
Old 01-28-2009, 10:12 PM   #4
JohnH1's Avatar
Was the venting of the attic/roof changed? This could definatly be a possability.
Old 01-28-2009, 10:18 PM   #5
Nope same old vents as always I really cant think of any major changes but the roof..I thought maybe the colder temps here in Indiana are alot colder then they have been in a few years
Old 01-28-2009, 10:20 PM   #6
JohnH1's Avatar
Could be. Are you maby running a higher than normal humidity with a humidifier?
Old 01-28-2009, 10:22 PM   #7
Nope i dont use a humidifier at all...
Old 01-28-2009, 10:34 PM   #8
JohnH1's Avatar
If you have access to the attic make sure the metal boots are insulated. If it is the cold causing swetting this should help.
Old 01-28-2009, 10:40 PM   #9
im about ready to just go up in the attic and take the flex ducts out since i dont even use the furnace anymore...
Tags
vent , water
Hot water boiler furnace-insufficient heat Nashman HVAC 2 11-06-2011 07:15 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
Finned-tube elements for hot water baseboard heat SureBert HVAC 2 12-05-2008 06:01 PM
Heat vents near ceiling Cossack General DIY Discussions 3 04-13-2008 09:31 AM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
