Water Dripping From Evaporator - HVAC - DIY Chatroom Home Improvement Forum
Old 04-13-2014, 12:11 AM   #1
Rewards Points: 85
water dripping from evaporator
At the end of the a/c season last year I noticed water coming from the furnace. I opened it up and saw water dripping from the coil. I went to Home Depot and bought some foaming coil cleaner and cleaned it a few times but it still dripped a bit. The foaming coil cleaner slowed the dripping but at the end of the season it was still dripping a bit. Can someone recommend a good coil cleaner, maybe a concentrate that I could mix and then use on the coil. I would like to clean it before the a/c season using some kind of cleaner and then rinse it with water so as not to let the cleaner dry on the coils.
boilermaker27 is offline   Reply With Quote
Old 04-13-2014, 05:47 AM   #2
An old Tradesmen
Rewards Points: 6,476
http://www.nucalgon.com/products/aer...-foam-no-rinse
Old 04-13-2014, 09:56 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
I like to rinse them to make SURE the coil is draining properly along with the drain line. The crud washed off the coil can plug the drain hole or line. Then it overflows and blows the circuit board.
Dripping sound but no water marks takingtoolong Plumbing 11 03-15-2014 12:59 PM
Water Dripping From Circuit Breaker Box/Frayed Service Line Magnetic Electrical 6 02-03-2014 04:50 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
