Water Drian Issue For Mini Split AC System - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-29-2014, 06:45 PM   #16
Rewards Points: 282
Originally Posted by yuri View Post
My experience is that dust/dirt is in the drain water and it eventually forms sludge/crud and especially in the off season. Never good to have any horizontal pipe in a gravity drain like that. Unless you want to clear it once a year with bleach it will eventually plug up.
Makes perfect sense. Do think it makes sense to open up the wall on the outside /other side where the minisplit is installed.
so that I can provide the drain in a vertical line !!
What is the best way to open the wall on the other side at the bottom or the top ?
If it is at the top, I need to run all the tube outside.
does this makes sense ?
cprao is offline   Reply With Quote
Old 07-29-2014, 10:24 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 92
I don't know, cannot see it from here. Every one has a different wall and setup. Have to come up with a method and seal it so no water gets inside the wall. I don't do installs. I have a crew who does.
Post a pic of the wall and someone else here may be able to give you more info.
Old 07-30-2014, 03:58 AM   #18
Rewards Points: 29
Do you have any slim duct on the outside of your house for the line set? We usually feed the condensate line out with the line set and down in the slim duct.
Sent from my iPhone using diychatroom.com
Ben25 is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Need Help Buying a Sediment and Water Softener System. vpr80 Plumbing 10 02-23-2012 10:26 AM
Potential Water Issue in New Shower? cobrakai Kitchen & Bath Remodeling 4 02-12-2011 05:36 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
