Old 12-11-2012, 06:29 PM   #1
Water/Condensation Leak in Trane XR95
Recently found some moisture under my Trane XR95 in my attic while pulling out xmas stuff. I put a small pan under where it looked to be coming from and checked back after about a week.
The heater seems to be working fine and we have been using it on a daily basis.
Today after seeing how much water was in the pan, I took a better look and traced the source to here...
The water is coming out of the joint for the exhaust flu, then dripping down to here...
Then inside...
Then over to here, and onto the attic floor.
Anyone familiar with the Trane xr95's that might have seen this before?
Thanks in advance.
JLOC is offline   Reply With Quote
Old 12-12-2012, 07:51 PM   #2
Experienced HVAC Tech
Alright I searched all over for an answer for u and i found an old guy (my dad) who used to do nothing but Trane equipment and he has seen this problem before. After turning off the furnace or at least the gas, you need to remove the flue pipe a few inches above the leak all the way down to the rubber coupling that connects it to the inducer motor. From there replace the whole length of pipe and elbow make sure it is all glued tightly. Reconnect to rubber coupling in unit and install a new rubber coupling in the other end of replaced section. This is the easiest way to replace the section plus the two rubber couplings in the line make any future repairs or parts replacements easier to access. Oh and you must absolutely make sure the flue pipe slopes back to the furnace so all condensation will drain properly to the unit. Sorry for such a long message but I hope it helps you
HVAC1000 is offline   Reply With Quote
Mystery Leak Running Out Of Ideas... miamicuse Roofing 24 11-17-2012 05:49 PM
Trane XR95 - how to adjust fan speed? Steve19 HVAC 3 09-17-2011 06:10 PM
Trane XR95 Problems cipherman HVAC 8 09-17-2011 05:02 PM
Trane XR95 - want to wire a manual blower switch hellothere123 HVAC 3 06-12-2011 11:25 PM
Trane A/C has a constanat leak when the unit is on but when I turn it off it stops MBFULTON HVAC 2 09-25-2010 12:53 PM
