Water Coil Always Being Heated - HVAC - DIY Chatroom Home Improvement Forum
Old 10-03-2012, 12:47 PM   #1
Water coil always being heated
I'm renting my first house have baseboard water heat. a coil in my furnace. Is it usual for the burner to come on when your baseboard thermostats are off and there is no hot water being used? It seems to fire up hours after someone has taken a shower or washed dishes/hands. all summer this has happend. Is it regulating something in the furnace even though no ho water is being used??? Thanks
Smokeyg is offline   Reply With Quote
Old 10-03-2012, 03:48 PM   #2
are you saying that you have hot water baseboard heat using a boiler and the boiler also heats your hot water for showers? the boiler is set to maintain a certain water temp so when you need heat the hot water is there. when you are calling for heat it will also shut the burner off for a while when the temp has been met even tho it is still circulating the water heating the rooms.
Old 10-03-2012, 06:05 PM   #3
An old Tradesmen
Rewards Points: 6,544
Post pics of your boiler.
Not uncommon for the boiler to fire up anytime it needs to to keep itself hot so you can have hot water anytime you might use it.
Old 10-09-2012, 07:13 PM   #4
Rewards Points: 266
The controls can be modified to let it cool off when you are sleeping or out of the house if your schedule is compatible.
ionized is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
What is this HVAC Heat Pump System - Water Pipes To Indoor Coil? kentkeith HVAC 20 01-17-2011 05:07 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
