Old 07-28-2010, 02:20 PM   #1
Water from bottom of furnace????
Many "drips" to the floor and then running to basement drain.
Only happens when AC is running.
After examining the whole setup, it seems to me that the ductwork leading from the furnace is "sweating" or "condensing" very heavily. The water is then leaking down the furnace to the floor.
1. Is this a possible/probable source of the water?
2. If so, how can I fix it?
2. Any other ideas greatly appreciated. TIA.
fragonardium is offline   Reply With Quote
Old 07-28-2010, 04:34 PM   #2
Insulate the duct that is sweating with duct wrap that would stop the problem... I'm assuming your plenum / duct is much colder then the surrounding air temp and that the air in the area around the furnace / duct is much more humid... this woudl create condensation and the only ways really is to dehumidify the air in the room or to insulate the duct work
BlueBSH is offline   Reply With Quote
Old 07-28-2010, 05:09 PM   #3
Thanks much.
Is "duct wrap" something that I can get at one of the big box stores?
Old 07-29-2010, 12:46 PM   #4
yep you can buy it at places like Lowes and HD... you get foil faced fiberglass duct wrap for the easiest install or Reflectex for a little more complex one
Furnace leaking water Red Squirrel HVAC 5 09-22-2009 04:13 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Converting from furnace to how water heater skittlzski Plumbing 2 05-16-2008 11:10 AM
Water on bottom of furnace timkay2 General Discussion 5 10-17-2007 09:27 AM
