-   -   Water from bottom of furnace???? (http://www.diychatroom.com/f17/water-bottom-furnace-77356/)
fragonardium 07-28-2010 02:20 PM
Many "drips" to the floor and then running to basement drain.
Only happens when AC is running.
After examining the whole setup, it seems to me that the ductwork leading from the furnace is "sweating" or "condensing" very heavily. The water is then leaking down the furnace to the floor.
1. Is this a possible/probable source of the water?
2. If so, how can I fix it?
2. Any other ideas greatly appreciated. TIA.
BlueBSH 07-28-2010 04:34 PM
Insulate the duct that is sweating with duct wrap that would stop the problem... I'm assuming your plenum / duct is much colder then the surrounding air temp and that the air in the area around the furnace / duct is much more humid... this woudl create condensation and the only ways really is to dehumidify the air in the room or to insulate the duct work
fragonardium 07-28-2010 05:09 PM
Thanks much.
Is "duct wrap" something that I can get at one of the big box stores?
BlueBSH 07-29-2010 12:46 PM
yep you can buy it at places like Lowes and HD... you get foil faced fiberglass duct wrap for the easiest install or Reflectex for a little more complex one
