Want To Replace Exhaust Fan Motor - How To Remove Blower Wheel? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-04-2013, 09:53 AM   #1
want to replace exhaust fan motor - how to remove blower wheel?
Hi,
We need to replace the motor in our bathroom exhaust fan.
I've located a replacement motor online. Now I need to remove the squirrel cage blower wheel from the old motor so I can put it on the new one.
How do I get it off? There isn't any sort of nut holding the wheel to the shaft that I recognize. It looks like a half circle. Is there a special wrench to use? I tried gently pulling it off but no go.
thanks
ChrisJJ is offline   Reply With Quote
Old 03-04-2013, 09:59 AM   #2
DIY staff
Rewards Points: 7,174
Post a picture---could be a circlip---
Old 03-04-2013, 11:44 AM   #3
Roofmaster
Rewards Points: 2,210
Bathroom fans are usually disposable, unless it is an old made in USA quality fan. Is your blower wheel plastic? If there is no set screw to the flat spot on the shaft, it is Probably pressed on, so you have to press it off, if you can, without breaking it.
Pictures Please.
Old 03-04-2013, 11:47 AM   #4
Rewards Points: 14,010
Might want to check one of the box stores. I know they stock some. The ones I've bought already had the fan on them.
Remove half walls & replace with wood railing/balusters jjgoss Remodeling 3 06-29-2010 08:05 PM
Removing Furnace Exhaust Blower Stevie HVAC 0 12-13-2009 06:27 PM
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 10:00 AM
Remove and replace single duct span i8kermit HVAC 3 07-31-2008 01:31 PM
How to remove drip edge to get to replace fascia board mr-hobo Roofing/Siding 2 07-14-2008 09:28 PM
