Want To Install A Narrow Shelf Above Hot Water Baseboard Heater... - HVAC - DIY Chatroom Home Improvement Forum
Old 09-26-2012, 12:57 PM   #1
Want to install a narrow shelf above hot water baseboard heater...
Hi there! I want to install a 4" deep book display shelf above a hot water baseboard heater. I need it to be low -- partly because it's meant to hold the kids' books, and mostly because it would be installed on a half-wall that opens to the basement steps. If I were to install it higher than about 3" above the top of the heater, I'm afraid the kids might try to use it as a step to get over the wall... which would lead to a nasty fall. The shelf would be 8' long and located above 15% of the length of baseboard heater in this room. Any advice as to how close to the top of the heater I could install this without compromising the heater's ability to keep us warm? Thanks!
nhwoodhobbyist is offline   Reply With Quote
Old 09-26-2012, 02:40 PM   #2
biggles's Avatar
15% of the heater isn't a deal breaker on the heat rising out of that baseboard...the books might take a hit,but the heat will just roll up and over the shelf.is the baseboard on an interior or perimeter wall?
Old 09-26-2012, 03:21 PM   #3
Thanks for your response! The baseboard is on an interior wall. So if the heat would just roll up and over, then would I be okay installing it just an inch or two over the heater?
Old 09-26-2012, 03:39 PM   #4
Rewards Points: 610
IMO..Shouldn't be a problem. Just increase your fire insurance. lol..just kidding
techpappy is offline   Reply With Quote
Old 09-26-2012, 03:56 PM   #5
An old Tradesmen
Rewards Points: 6,072
Is this cast iron baseboard, or copper tube and finned baseboard.
Old 09-26-2012, 04:05 PM   #6
It's copper tubed and finned. The heater itself actually doesn't get very warm. I just don't want to keep it from doing its job.
Old 09-26-2012, 04:29 PM   #7
An old Tradesmen
May dry out books being so close to baseboard. Could warp the bookshelf too, it will dry out the wood and paper. So no candles or sparks near the shelf. But no other real harm.
Old 09-26-2012, 05:27 PM   #8
Thanks so much! I'm planning on just setting the books we're planning to read for the week there, so nothing should be stored there long-term.
Old 09-26-2012, 06:55 PM   #9
biggles's Avatar
what you could do instead of a shelf is a rail type book holder like in the book stores have,lenght of furring strip or even 2 finishing nails to hold each books up....at an angle.hang a fish net type fabric to drop the books in
Water heater issues?!? NJdan Plumbing 1 06-04-2015 08:42 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Is this water heater install legal? aoliver Off Topic 9 04-04-2010 06:30 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
