Prev Previous Post   Next Post Next
Old 10-16-2009, 05:28 PM   #1
Question Want to install combustion air venting
I have a natural gas furnace that is power vented and uses the basement air for combustion, its a 1993 Heil furnace. Sticker inside says input BTU is 75,000 and output is 59,000. I want to install a duct that is located about 1 foot off the floor near the furnace to help supply combustion air to the furnace. I am thinking of installing 4 inch duct that is vented from the outside and has a motorized damper that opens when the furnace runs.
Is 4 inch sufficent?
Is a motorized damper needed or is there a passive type that would work?
Should the ducting be rigid and insulated?
Should a fan be installed to increase air movement toward the furance end?
Thanks for any input
creamaster is offline   Reply With Quote
More On This Topic
What Do Spark Plugs Do?
What Do Spark Plugs Do? by Expert Village
Hi my name is John, on behalf of Expertvillage.com. In this video clip I will explain what spark plugs actually do. As we take a look at this engine cut away there is a couple of things I wanted to point out, right here we have the piston and we have our... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Hi this is Jeff Wong with Expert Village and today we're going to learn the basics of maintaining your vehicle. So this car as with most cars that are parked outside tend to gather leaves and other debris in the top intake vents and along inside the... Read More »
One of the biggest challenges in maintaining a greenhouse is humidity control. Most plants enjoy a humidity of 50 to 60 percent, and this is a challenge to manage at times. The main goal is to avoid condensation on plants, which promotes mold and fungus... Read More »
Sealed Combustion Furnace and Tank Hot Water Heater Yippee HVAC 6 06-16-2009 02:32 PM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 11:05 PM
Blocked Attic Soffit Vents on North Side - How to Improve Venting Jes Roofing 5 05-06-2008 11:35 AM
Furnace venting questions Mastiff HVAC 4 02-15-2007 09:27 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
