Walls Around HVAC - HVAC - DIY Chatroom Home Improvement Forum
Old 08-08-2006, 11:09 PM   #1
Walls around HVAC
I am building a house in a subdivision that requires a wall taller than the HVAC unit be built on the roof to conceal the HVAC unit from the front street view. (Southwestern syled house, flat roof, with parapet walls.) At least one side of the wall will be completely open and there is no top. I have two HVAC units going up. (2 ton and 4 ton) One will have a 3-sided wall, the other a 2-sided wall. The walls are 5 feet tall in order to conceal the Carrier units. How much space should be between the wall and the unit? (Has anyone ever heard of having to put walls on your roof?)
Not Sure is offline   Reply With Quote
Old 08-15-2006, 09:47 AM   #2
Rewards Points: 150
Best check with Carrier. They will give you exact clearances required. Most likely got a pdf on their site someplace with all the info.
scorrpio is offline   Reply With Quote
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 02:43 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
HVAC plans for remodel wease HVAC 3 03-23-2011 11:47 AM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 04:07 PM
