Wall Prep For Wall Mounted Space Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 05:59 PM   #1
wall prep for wall mounted space heater
Utility room . Installing LP gas wall heater. Walls are currently studs with insulation in the. Do I need to put drywall on the wall to instll the heater? Thanks, Mary
mary574 is offline   Reply With Quote
Old 11-14-2011, 06:24 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 174
Depends on the specific clearances in the install instructions and your local bldg code and the gas code. Whichever is the greatest distance you have to follow. Good idea to put drywall there. Some manufacturers are now giving the gas code info with their instructions.
The Following User Says Thank You to yuri For This Useful Post:
mary574 (11-14-2011)
Old 11-14-2011, 06:34 PM   #3
Rewards Points: 582
agree with yuri good idea to put drywall on wall also check local codes for this type of install...ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 11-15-2011, 02:58 PM   #4
Thanks again. I got thefire resistent drywall. CAn I just patch where it is going on or do I have to drywall the room?
Old 11-15-2011, 03:05 PM   #5
Rewards Points: 582
it would seem to me all you have to do is provide backing for where the heater is going to be and a few inches past for protection....
mary574 (11-15-2011)
Old 11-15-2011, 04:11 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 174
Check the local codes. If something goes wrong you can be liable and your house insurance void etc etc. As they say: Ignorance of the Law is no excuse.
Cadet wall heater Jack E HVAC 1 04-21-2010 04:55 PM
GFCI for wall mounted aquarium LOST VEGAS Electrical 4 04-19-2010 06:58 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 10:28 AM
