Old 02-15-2012, 03:47 PM   #1
Wall Heater delay then Gas explosion.
Hello guys. I have a customer who has a wall heater . Its a williams. The tenant says: " You turn it on from the thermostat. It has a delay before ingnition light. about 7 seconds. Then it lights up.actually from their description the gas" Explodes" and fire shoots up the top of the unit and half the house shakes. I understand this is extremely dangerous , It is currently shut down . Non operative. but short of condemning this 1960s unit, is there a typical culprit and remedy for this kindof situation? Thank YOu again,
curtis19 is offline   Reply With Quote
Old 02-15-2012, 04:01 PM   #2
I doubt that old a unit is even worth working on.
Old 02-15-2012, 04:50 PM   #3
been there done that
delayed ignition is almost always caused by a dirt or dust build up, and or some kind of mis alignment with the burners.
dosy777 is offline   Reply With Quote
Old 02-15-2012, 05:50 PM   #4
how
The pilot can be soft (dirty pilot orifice or pilot assy debris) so that the pilot flame is no longer close enough to the burners. The crossover may be dirty which allows one burner to ignite normally but the other burners have a delayed ignition.
The main burner is dirty where the pilot ignites the main burner so that you have a delayed ignition.
Either way you should get a pro to tell you if those explosive ignitions have damaged the unit and made it too unsafe to keep.
how is offline   Reply With Quote
Old 02-15-2012, 10:39 PM   #5
perform a detailed cleaning on burnner assy check pilot and clean orifice if needed .. reset unit try again if it does not work replace unit with new wall unit..
ben's plumbing is online now   Reply With Quote
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Electric Wall Heater Shield JTee Electrical 1 02-13-2011 01:35 AM
Correct gauge wire on wall heater?? Master Brian Electrical 4 11-16-2010 02:48 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Lear Siegler Wall Heater back clearance Steve Burke HVAC 4 09-19-2009 05:22 PM
