Wall Furnace Pilot Burner Tube - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2011, 10:21 PM   #1
What is the correct way to install 1/4 inch break away nuts on aluminum tubing for the pilot light and gas valve fittings?
retiredone_04 is offline   Reply With Quote
Old 10-29-2011, 04:48 AM   #2
An old Tradesmen
Rewards Points: 6,918
Slide it on the tube. Insert tube into valve/pilot, then tighten.
Old 10-29-2011, 01:40 PM   #3
Do I slide the tube all the way down into the valve/pilot ports until the tube bottoms out, then hold the tube and start tightening the break away nut?
Old 10-29-2011, 02:49 PM   #4
An old Tradesmen
I do.
The Following User Says Thank You to beenthere For This Useful Post:
retiredone_04 (10-30-2011)
Old 10-29-2011, 06:43 PM   #5
Rewards Points: 582
same here let me know if you have another way.Ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 10-30-2011, 02:21 AM   #6
The reason I'm asking about the breakaway nut is because I was told I had a bad valve on my wall heater. I bought a replacement gas valve on-line at a cost of $50.00, which was not the same as the original gas valve. I then had to re-route the pilot light burner aluminum tubing. In the process of going through these changes, I broke the pilot light burner aluminum tubing. I then replaced the pilot light burner aluminum tubing and incorrectly installed the break away nut and then stripped the threads on the gas valve. I had to buy another a gas valve from a local hardware store at a cost a $104.00 and I am trying to avoid this from happening again. These gas valves are not cheap.
Old 10-30-2011, 02:33 AM   #7
REP
Do exactly like you said in reply #3.When you hear or feel "the break" then stop,you are done.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
Old 10-30-2011, 03:12 AM   #8
Thanks to all for replies. I am going to follow reply #3 after I install the new gas valve.
Hoping you all have a warm winter.
From,
retiredone_04
Old 10-30-2011, 06:16 AM   #9
An old Tradesmen
Cross threading will be you biggest concern.
Old 10-30-2011, 06:44 AM   #10
beenthere:
I hear what your saying.
The new gas valve I bought came with an extended breakaway nut, not like the "NEW GAS VALVE" I bought on-line.
This will allow me to have more visual control of the aluminum tubing while I slowing tighten the breakaway nut.
Old 10-30-2011, 11:30 AM   #11
I think their biggest concern should be that the new control valve is not the same as the original. It could be for a different fuel, designed to deliver higher BTUs, etc.........
log_doc_rob is offline   Reply With Quote
Old 10-30-2011, 11:58 AM   #12
@log doc rob, I purchased the Robertshaw 710-502 millivolt natural gas valve with a thermopile setup which replaces my "old" ITT General B67 gas valve.
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Fixed pilot light, now furnace or AC won't turn on mjcfromct HVAC 2 10-17-2011 10:46 PM
Heil Furnace Pilot Light Not Igniting shwank HVAC 13 10-07-2010 06:41 AM
Condensate tube from furnace billthecat Plumbing 8 08-05-2009 07:38 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
