Wall Furnace Emits Slight Warmth At Middle/top Grilles Of Front Vent While Off - HVAC - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 11:49 PM   #1
Rewards Points: 366
wall furnace emits slight warmth at middle/top grilles of front vent while off
Home had a new gas wall furnace installed recently (and connected to a furnace vent pipe that goes up the attic to the roof). It tested to be working, and I noticed that the furnace while off still emits slight very faint warmth at middle to top grille area of the front of the furnace. The bottom of the front and the side grilles don't emit such warmth.
You only notice this warmth by placing your hands over the grilles of the furnace casing at the middle/top in front. Otherwise, you won't really notice.
Is this normal or does it indicate potential problem? I haven't really worked with a wall furnace before.
daluu is offline   Reply With Quote
Old 02-26-2012, 12:55 AM   #2
how
Rewards Points: 1,104
A new wall furnace with a standing pilot???
Doesn't the front cover come off for you to take a look?
A picture would help!
how is online now   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
plummen (02-26-2012)
Old 02-26-2012, 07:38 AM   #3
Residual heat off the heat ex.
hvac5646 is offline   Reply With Quote
Old 02-26-2012, 07:42 AM   #4
Experienced
Jackofall1's Avatar
^^^^^^What he said
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Furnace front clearance owner95112 HVAC 19 12-19-2010 12:22 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 10:28 AM
