Wall Furnace Change-out - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2006, 10:13 PM   #1
Wall Furnace change-out
I have a 1080 sf 3 bdrm 1 1/2 ba hse blt in 1955 in Southern Calif.
I had the dual wall floor frunace replaced with a dual wall 50,000 BTU Wialliams frunace. Didn't have it inspected but the plumbing contractor told me he installed it per code.
When I looked at the installation instructions it says there should be at least 4 ft. clearance form the face panel to any object. One side of my furnace is in a hallway and the hall width between the frunace face panel and a linen closset directly accross from it is 2 ft 10 inches.
Anybody know what the California Building code is for this situation? Now I'm concerned that it may not be installed per code. But I don't know where else it could be installed and it was replacing an old floor frunace with wall panels that rose about 2 ft, one either side of the wall.
Thank youfor any replies.
Calhoun is offline   Reply With Quote
Old 11-10-2006, 11:01 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi Calhoun
I am not sure of the mechanical codes for Califonia, you guys have to deal with some really silly stuff. Here is a website that might give you some insight to your question.
<LI class=first>www.bookmarki.com/California_First_to_Adopt_2006_Uniform_Plumbing_and_Mechani_ s/241.htm
#CARRIERMAN is offline   Reply With Quote
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 04:05 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
